DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Install double switch
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  Bookmark and Share View previous topic :: View next topic
Author Message
JohnT
from United States of America
Thanked: 0 times
PostPosted: Mon Feb 02, 2004 8:07 pm    Post Subject:
Reply with quote Thanks
I am a complete novice to wiring. I need to put in a double switch for fan and lighting in bathroom. The fan was disconnected long before I moved in so I don't know how it was originally wired. I pulled the plate and found one red wire to bottom of light switch and one black one to top. I also found two white wires taped together with black tape, and part of the black wire was taped to reveal two black ones further on. The green ground wire is wired to the handy box. How do I wire this up on a double switch which I purchased, has two screw connectors on each side and ground at top, 15amp 120 leviton switch. Any help greatly appreciated. I am located in USA
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
James Brown
Guest
Thanked: 0 times
PostPosted: Wed Feb 04, 2004 8:58 pm    Post Subject:
Re: Install double switch
The best thing to do is start form scratch! you need 1. double pole Isolation switch, 2. Cable 6242Y 1.5mm (for thermal volt Drop in Roof) 3. New fan.
Put the Isolation switch out side of the room were the fan is. Wire the fan as you would a light, use the light in the bathroom phase(live) neautral and earth( you might not need a earth if it is double Insulated) to the double pole switch then to the fan. make sure you switch off you power supply at you consumer unit (fuse box). And make sure the lighting circuit can cope with the supply demand of your new fan. icon_idea.gif if in dout consult a electrician. Make sure he fan is out of reach of water.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 6 times
PostPosted: Wed Feb 04, 2004 10:15 pm    Post Subject:
James, America has different cable sizes and regulations than we do, i doubt if JohnT will understand what you mean icon_cry.gif
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
JohnT
Thanked: 0 times
PostPosted: Thu Feb 05, 2004 11:03 pm    Post Subject:
Thank you for the response, at one time there was a single switch that operated both the fan and the light when turned on or off. This is a 120 Vt box 15amp load. I dug around a little and found out the red wire is generally pre-wired by housing contractor when built in the event a heavy load will be used. The information I got on this is that I need to put a jumper on the double switch lugs top and bottom, run one leg of black to same top lug on left side of switch lugs, than install nuetrals to the right side top and bottom lugs. Put electrical tape on red wire and bury in box (no use) and than test.
I will let you know if it works and I appreciate your response.
Thanks again.
Back to top
 Alert Moderators
smithman
from Canada
Thanked: 0 times
PostPosted: Fri Feb 13, 2004 3:56 am    Post Subject:
installing double switch
Since you are a complete novice at wiring-- take a course at your local college or call an electrician before you burn your house down
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Air con install (spain) 12 1420 Wed Jul 26, 2006 10:49 am
install ceiling fan light 6 1020 Sun Jun 28, 2009 6:24 pm
to install 2 motion dectectors (3-way) on the same circuit 4 1000 Mon Sep 24, 2007 6:45 pm
replacing a double switch with a single dimmer 3 1100 Wed Feb 02, 2005 10:31 pm
Double switch (2-way) installation? 5 1380 Sun Sep 12, 2004 6:39 am
Volex 1G 1W 500W Touch Dimmer Satin Chrome Flt Plt Volex 1G 1W 500W Touch Dimmer Satin Chrome Flt Plt£24.00Twin Double Socket Polished Chrome - White
Twin Double Socket Polished Chrome - White£5.30
Volex 10A 1G 2W Sw Wht Ins Satin Chrme Angled Edge Volex 10A 1G 2W Sw Wht Ins Satin Chrme Angled Edge£3.74Satin Chrome 1 gang size 45a DP switch - White
Satin Chrome 1 gang size 45a DP switch - White£5.75
DIYnot
