AEG 72630 (update)
cam
17 Sep 2006
Surrey
machine stopped in the the middle of a cycle, showed the code e20 and now will not drain. Is doing nothing... Help! please.
You've answered your own question. E20 is a draining failure.
Blockage in the sump hose, pump, drain hose or faulty pump.
Clear the blockage or replace the pump if faulty and you'll clear the fault.
Use calgon in future, it's probably blocked with limescale. The common error codes are listed in the manual if you've still got it. E20 is the most common, and as said is a drain filter blockage. If you've lost the manual, you can get it off the interweb.
