stevemcevoy07
Joined: 18 Sep 2006 Posts: 6 Location: London, United Kingdom Thanked: 0 times
Posted: Mon Sep 18, 2006 12:24 pm Post Subject: Installing new W/M drain pipe |
Hi I am just in the process of connecting up a new w/m and unsure of whether I need to connect the u-pipe. The w/m sits underneath the drain tray of the sink. I have passed the drain pipe up and over the dividing wall seperating the w/m and the spigot. I have connected the drain pipe to the spigot with a jubilee click. The pipe then goes up and over the side panel, but does not form a u shape, more like a a long arc. The hide of the highest point is basically just underneath the sink, standard height.
I am just a little concerned at starting the washing machine in case it does not drain correctly |
Sleepyhead
Joined: 02 Apr 2006 Posts: 1896 Location: United Kingdom Thanked: 4 times
Posted: Mon Sep 18, 2006 3:11 pm Post Subject: |
As long as the plug or blank end of the spigot are removed you should have no problems with that set up. |
stevemcevoy07
Posted: Mon Sep 18, 2006 3:20 pm Post Subject: Installing new W/M drain pipe |
Thanks for that. |
