DIYnot
Local | Network
   DIYnot > Forums
Local | Network
How to set up footings square to house.
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
diyisfree
from United Kingdom
Thanked: 1 time
PostPosted: Mon Sep 18, 2006 3:53 pm Reply with quote
I have roughly dug out the footings for my new conservatory, i am hoping to set the levels tomorrow before pouring the concrete this weekend.
I want to ensure the footings will be square to the house wall and also the the walls will be square to each other.
If the size of the footings are 5550mm wide and 4000 from the house wall to the exterior of the new walll, do i then measure from corner to corner to see if its square ? And if so, what should the measurement be ?
I cant decide how i would go about working this out.
Any thoughts guys, and galls
Cheers.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1290 times
PostPosted: Mon Sep 18, 2006 5:02 pm Reply with quote
the diagonal measurement, provided all the corners are square should be 6841mm. measure both diagonals to get a more accurate measurement.
we use the 3,4,5, theory to check or set out square buildings.it too is based on pythagarus's theory.
if one side measures 3 units the adjacent side measures 4 units then the diagonal will be 5 units.
Back to top
 Alert Moderators
diyisfree
from United Kingdom
Thanked: 1 time
PostPosted: Mon Sep 18, 2006 5:28 pm Reply with quote
Hi Noseall
Yes i worked out the 6841 myself in the end. I have now adjusted all the lines and to be honest, they werent that far out. But as you state " so long as all the corners are square"
So measuring the diagonals still isnt sufficent to say the marked out area is square then ?
this 345 rule, if i knock up a few bits of 3x2 and make a blooooody big triangle, then place that against the wall, is that what your saying ?
Thanks for taking the time to respond by the way...
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1290 times
PostPosted: Mon Sep 18, 2006 6:13 pm Reply with quote
yes, if your diagonals are to within say 5mm of being equal then you've cracked it.
you can measure the adjacent walls to check the 3,4,5. you can measure 3mm, 3inches 3 feet or 3 metres, you don't have to go all the way to the next corner to check, though the longer the increments the more accurate it will be.
Back to top
 Alert Moderators
diyisfree
from United Kingdom
Thanked: 1 time
PostPosted: Mon Sep 18, 2006 8:57 pm Reply with quote
Ah got what you mean now.
So lets say i measure 3 feet of the exsisting wall and put a chalk mark, then 2 feet up the line i have just laid down and again a chalk mark, I then measure between these 2 points and it should be 5 feet.
easy when you explain..
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 1290 times
PostPosted: Mon Sep 18, 2006 9:23 pm Reply with quote
almost there. the increments are always 3,4 and 5.
so it's 3 feet along the wall, 4 feet up the line and 5 feet will be the diagonal between the marks.
look at the square(ish) tele or monitor for example.
starting from a bottom corner, measure up three inches, put a mark, measure across four inches, put a mark. then the measurement between the marks will be five inches if the monitor is 90 degrees.
Back to top
 Alert Moderators
diyisfree
from United Kingdom
Thanked: 1 time
PostPosted: Tue Sep 19, 2006 7:44 am Reply with quote
Hi Noseall,
Yes sorry slip of the finger. 2 was meant to be a 4
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
The knack of Setting out brickwork square to house 2 920 Mon Jan 28, 2008 8:11 pm
New house out of square 5 200 Sat Jan 28, 2012 11:35 pm
how to square ext to unsquare house 7 760 Wed Jan 31, 2007 9:34 pm
Small square bricks/ready made headers? 10 180 Thu Nov 03, 2011 12:50 pm
Can I remove this square of concrete myself? 3 280 Mon Nov 22, 2010 3:46 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
