Radiator Valves 15mm or 1/2 inch
28 Nov 2005
This is a silly question to all those that know the answer...
I'm changing the TRV's and lockshield valves on my rads and moving the roomstat as per a previous post.
Been to the shed for the lockshields today and had the choice of 15mm at £2.18 or 15mm 1/2 inch at nearly a fiver.
I bought the cheaper one and the tail fits my rads but as they're pre-ancient and possibly around 30 years old I wonder if they need the 1/2 inch version.
Is this an interchangeable unit between metric and imperial?
Further to this I've got 15mm Drayton TRV 4's, should they be a 1/2 inch version too?
Sorry for a dumb moment question but need to get on with hanging these rads.
The copper pipe could be 15mm or 1/2". If the compression ring that comes with the valve fits over the pipe, then it is 15mm. you should then be able to fit the valve with out a problem.
I've just tried the new olives on the existing copper pipes and a piece of new pipe and they fit on both pipes the same.
A further point would be that as the old pipes are very slightly waisted where the previous compression joint was will this seal OK with new olives and fittings?
