radiator problem
18 Sep 2006
Yorkshire
I have a Classic LXRS boiler, with a hot water tank, when the hot water only is selected the radiators become hot, anyone know the problem and a cost effective solution?
with the little information its sounds like the motorised valve could be letting by.
what other info is required for a better / more educated guess?? the boiler is 10 years old is it worth repairing or should we replace it ??
thanks for your previous answer
:evil: :evil: :evil: Aha! One of those old boilers still going at 10 years!! Old technology, suck teeth, could GO at any time. Regulations, inefficiency, problems. Terrible.
You want it out really, before the winter... unless you want your other half after you when it breaks down... Better get it booked in...
Or you could fix the valve, and leave the boiler for another 20 years. Look for one of
these
thanks for the picture, I have found one of those in the airing cupboard, are they easy to replace ? mine has a pimple !! what does that mean ??
is there a link to the picture with directions?
thanks again
Martin, you need to drain the system or atleast to the level the valve is on.
and then just a case of 3 nuts (not position of AB, A and B ports) and exchanging wire for wire in the junction box.
not a very difficult job but you need to be competent in draining and refilling a conventional system.
*im assuming this is a recent problem nothing has been altered or touched prior to the fault as there is a slight chance it could be a wiring fault.
