DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
creaking chipboard floor
This topic originated from the How to page called Stopping creaking floorboards
Click here to return to the page called Stopping creaking floorboards.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
MolesDen
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 18, 2006 8:47 pm    Post Subject:
Reply with quote Thanks
I have a loft extension with a creaking T&G chipboard floor. I have screwed the boards down to the joists using God knows how many screws but they are still noisy which is driving us mad.
I am now thinking of srewing down 12 mm plywood sheets on foam over the chipboard floor.
Can anyonw tell me if this is likely to help or am I just waisting my time and money? Perhaps I should just take up the whole floor and replace it with standard floor boards! icon_sad.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Mon Sep 18, 2006 8:59 pm    Post Subject:
What sized screws did you use? Length and diameter?
__________________
If I'm curt with you it's because time is a factor. The Wolf.
Back to top
 Alert Moderators
CamperPete
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 19, 2006 8:57 am    Post Subject:
You sure it's flooring and not the joists that's creaking?.......just a thought icon_confused.gif
Back to top
 Alert Moderators
MolesDen
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 20, 2006 9:47 pm    Post Subject:
I have now replaced most of the existing 1 1/2" screws with 2 1/2" x no10 screws which has helped but not cured the problem. I have now decided to change all the screws with the larger size.
Fairly sure that its the joints between the boards that are creaking and not the joists. It also appears that where some of the boards meet there is no cross joist / nogging to support the joint. Presumably this doen't help either.
Still thinking about laying plywood. I might try laying just a couple of lengths to see if it works before I buy all the sheets I need.
I can't dither about much longer as I'm getting some serious ear bashing from the other half, so all suggestions would be appreciated and would help me to decide what to do.
Back to top
 Alert Moderators
Bungalow Boy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 01, 2006 9:41 am    Post Subject:
Creaking floorboards
Hi, I too have the same problem, having completed my self build around 2 years ago. I'm fairly sure that the creaking is caused by the board joints rubbing together rather than the joists. This is a bit weird as I used wood glue for all the tongue and groove joints. One thing that has helped is to paint wood varnish into the joints in a second attempt to stick them together. Let me know if you have any other solutions that I can try.
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Sun Oct 01, 2006 11:35 am    Post Subject:
if all the flooring is properly laid and if the joints are accessible pour a little talcum powder on them
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
MolesDen
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 08, 2006 6:52 pm    Post Subject:
I have now added lots more 2 1/2" screws, at least 3 per 600mm wide board in every joist and screwed them well home, and it has helped greatly to the point of being able to live with it.
I think I will also try the talcon powder method; I've heard this idea from a few different sources but apparently it is not a permanent solution.
I just hope the screws do not work loose after the carpet has been fitted and the furniture is in place.
I've decided that If they do come loose I'll have to wait until my son leaves home (no sign of that yet) and replace the whole floor with floor boards.
Thanks for everyone's comments.
Back to top
 Alert Moderators
rindo
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 31, 2007 8:24 pm    Post Subject:
HI, I thought it would be a good idea to tell anyone interested of a problem I have never encountered before, newish build, chipboard flooring, but the worst case of creaking I have ever heard. So what did I do, firstly I thought the boards were too tight, ran a circular saw along the joins to allow for movement, no joy, secondly, additional screws on the boards, no joy, by this time I was getting rather annoyed, took a board up, had a good look the joists were solid ? then quite by chance I tapped one of the cross beams noggins that were fitted between the joists to allow for screwing the plasterboard onto the lower floor ceiling, it was loose, they were all loose, held in by the occasional nail, they were the cause of the squeek/creak. a couple of nails on each noggin and Bob's your uncle.
Back to top
 Alert Moderators
Dizzysam
from United Kingdom
Thanked: 0 times
PostPosted: Thu May 07, 2009 7:58 pm    Post Subject:
Might work
Hey, know it's a long time since you posted but im new to this whole diynot thing and someone else but put my ideas to use.
May i suggest putting down 4 - 5 screws spanning across the 600mm width on each joist which will give it more strength over all and be generous on the glue you put on the tongue and grooving icon_smile.gif
If im wrong at all lemme know but it's what I have learnt so far as a 1st year apprentice
x
Back to top
 Alert Moderators
lennnnny
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jul 05, 2009 3:42 pm    Post Subject:
Squeeky chip board flooring
Try using the special foaming glue which is made for securing chipboard floars instead of nails or screws it's really impressive and means there's nothing for the floors to squeek again...Make sure you wear gloves as it does not come off.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
creaking T+G chipboard floorboards 6 2460 Thu Jul 01, 2004 6:41 pm
Creaking Floor - new build - really getting up my snout ! 2 900 Fri Jan 04, 2008 1:23 am
Junckers 14mm wooden floor [b]creaking[/b] when using clips 9 2340 Wed Dec 05, 2007 4:29 pm
Partition Wall Creaking against floor. 3 680 Tue Sep 18, 2007 12:15 pm
creaking /crunching floor boards on a new floor 6 1180 Mon May 08, 2006 9:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
