I am new so please bear with me!! I am in the process of knocking through my toilet and bathroom in to one,and this site has been a great help so far . I have taken down the partition wall and now have a lonley towel heater sitting room center,i wanted to remove and cap the pipes under the floorboards where they protude to meet the rail.
I have an emersion heater we use for hot water and a boiler we use for the central heating. i was under the immpresion they were two seperate entities but after advice to find a header tank in the loft ( or anywhere!) for the boiler ( I have one for my immersion heater)a small one they said IT MUST BE THERE!!I cant find one anywhere!! I closed off the valve on the old boiler (also no gauges to read on this thing just two square nuts to fit a red wheel on to close/open valves.it is a glow worm 45-60. ran rubber hose from the low drainage point on ground rad but nothing came out! I also attempted to undo a pipe on the towel rail and got a faceful of black water! (serves me right I know!)
But heres what I dont understand the most, I had turned off the water supply to my immersion heater during this attempt and when I turned it back on water flooded out of the top airscrew I had loosened on the towel rail. So I dont understand how I can have no header tank, a boiler
for just the radiators yet my water heating emmersion heater is involved in someway also!! my boiler is very old and is a Glow worm 45-60.
I thought combi boilers dont have immersion heaters,well in my old house they removed that and the header tank so im abit confused ,what system have I got here and how do I get to remove the heated towel rail?
One wheel on the boiler allows you to drain clear water and the other I think is an inlet (its just below the pump). I cant think of anymore info than that,hope you can help ,thanks.oh yes How do i know if the system has been refilled by me,is it ok just to check the rads bleed from the topscrew as I said there are no gauges on this one.
