DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing hot water inline washing machine tap
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
mleggatt
from United Kingdom
PostPosted: Tue Sep 19, 2006 6:45 am Reply with quote
A while ago I replaced the inline cold water tap on my washing machine (the one that isolates flexible hose from mains supply). It was stuck open and had been sealed using lots of plumbers mate.
I thought this had fixed the leak but it seems the hot water isolating tap is in the same state i.e. stuck open and leaking slightly. I want to replace it but am not sure how to cut the hot water.
I have a Saunier Duval combi boiler and I imagine I will have to turn the boiler off along with the cold water and then run the hot tap til the water runs out. The only point of concern is whether the boiler will need any maintenance other than turning the cold water back on e.g. airlock, valves inside boiler e.t.c.
Is it as simple as turning cold supply off, running hot tap til runs out and then replacing valve and doing reverse?
Any hints would be appreciated.
Martin
Back to top
 Alert Moderators
EliteHeat
from United Kingdom
Thanked: 2 times
PostPosted: Tue Sep 19, 2006 7:44 am Reply with quote
Exactly that simple
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Electric Inline Water Heater with a Mixer Shower 10 1220 Fri Jan 02, 2009 11:51 pm
Zip Inline Water heater Disagreement 3 180 Sun Oct 10, 2010 9:34 am
Does inline Scalemaster reduce water flow? 2 360 Mon May 11, 2009 10:03 pm
zip inline water heater 12 260 Sun Nov 03, 2013 4:08 pm
Inline water heaters or small unvented storage heaters 3 40 Mon Sep 12, 2011 10:40 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
