kaptainkondom
Joined: 22 Sep 2006 Posts: 16 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Fri Sep 22, 2006 3:21 pm Post Subject: TRV |
does a thermostatic valve need to be on the flow pipe? and can they be fitted to any rad? |
pannierstan
Joined: 01 Sep 2006 Posts: 670 Location: United Kingdom Thanked: 0 times
Posted: Fri Sep 22, 2006 3:46 pm Post Subject: |
Depends on the make and model of the TRV. Have you bought it yet as most new valves are Bi directional now (will go on flow or return)
Make sure your system is a straight forward 2 pipe system. If its less than 20 years old it should be.
The older one pipe systems sometimes had a control rad which I have seen fitted with a TRV and then wondered why the rest of the system went cold after the TRV shut down.
You shouldnt fit a TRV on the rad in the room where the room stat is. That is if you have a room stat
Regards
Stan |
kaptainkondom
Posted: Fri Sep 22, 2006 4:07 pm Post Subject: |
Thanks havent bought it yet so will get bi directional one! thanks for the quick response! |
