extending lighting spur
4 Feb 2004
I have a lighting spur from a 5 amp lighting circuit that currently switches on an interior and an exterior light at the same time.
I want to split the spur - install a 2 gang switch and switch the interior and exterior lights independently.
The lights run from a junction box at the moment. (Supply in - 2 lights & switch out).
Can I simply cut the supply and install a 2nd junction box. Then run supply in - light, switch and supply out (to next junction box). Finally running supply in - light and switch out at original junction box.
Or do I need to find the Lighting ring and take a new spur from there?
Thanks in advance...
Gio :confused:
if you are saying you have 2 lights controlled from one separate switch, but can see one cable from each light (2 in total) all you need to do is switch the switch to a 2 gang switch
it should be like this:
2 reds in L1 (from both lights)
1 red in c (from supply)
copy this to new switch.
take one red from L1 and put it into L1 of second switch(new switch)
put a 1mm (diameter) red wire from C (still has origonal red wire) into new C terminal put switch back, turn supply back on, have a nice day
Hi, Thanks very much for your reply.
Still not quite got it though.
The original set-up is like this... Switch has only 1 red in the L1 socket - this goes back up to junction box and branches to 2 lights from there.
Could I do as you said, patch red across the C inputs on a double switch, then take a single red from the L1 (switch 2) back up straight to the 2nd light (or back to the junction box - then to the light).
The Red from L1 (on the 1st switch) would now go back to the 1st light (or back to the junction box - then to the light).
Thanks again
G
so what is in C then?
it sounds like you will ned to run a new cable fom this junction box to the switch.
you must also identify which wire goes to which light (but you can do that by dissconecting one and seeing which light doesn't)
