where to join plaster board
26 Jul 2005
Leicestershire
Hi
Having read the previous posts on Dot and Dab I have one probably very simple question. The ceiling height is greater than the length of the plaster board by about 200mm. Is any particular method I should be mindful of when patching the remainder of the wall height with plaster board.
I was minded to cut the plaster board into two unequal large pieces using the longer piece from one board and shorter piece on a second baord. this will mean that I have a staggered join just below halfway on one board and just above halfway on the adjoining board.
Or am i getting my knickers in twist over nothing
if the skirting board is deep enough then have the cut at the bottom. the join will never be an issue this way.
Thanks for the quick response noeall. your point is valid in that much of the wall is being hidden by a new kitchen. One further question, will the adhesive hold the board onto the wall without support?
no it won't.
we use bricks, blocks, timber packers, any thing around the building site really. if you pack sensibly, you can use one packer per join.
Ok. at least I know. I will probably take the time to fit a batton to the wall as it is a long run.
many thanks for your posts you have been a great help.
regards
