DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch Classixx dishwasher not cleaning properly
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
xh28
from United Kingdom
PostPosted: Tue Sep 26, 2006 9:10 pm Reply with quote
We have had our Bosch dishwasher for about 4 years with no problem and it has just started not cleaning properly - getting wet but not clean. We have checked that the arms are moving freely, the water is heating up and that the soap is being released. Our water pressure is good and it is draining ok. We are running out of ideas.
If I had to guess I would say the bottom arm is not moving but I cannot see why - it is not snagged.
We welcome any suggestions.
Back to top
 Alert Moderators
baldy01
from United Kingdom
PostPosted: Wed Sep 27, 2006 9:01 am Reply with quote
We had this problem with our Bosch. Try checking the non-return valve for the waste pipe. Its normally a small rubber circle thats attached to a larger rubber block by a flap. Its normally fitted under a screwed down cover by the filters. The attaching flap stretches causing the rubber valve to wedge against the side of the pipe thus allowing waste to be sucked back in by the pump.
Your dishes effectively get rinsed in the mank allready washed off.
Worth a look.
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Wed Sep 27, 2006 6:41 pm Reply with quote
Check the spray arms for blockages. If the end holes are blocked then the arms don't rotate.
Back to top
 Alert Moderators
xh28
from United Kingdom
PostPosted: Wed Sep 27, 2006 9:41 pm Reply with quote
Hi
I think Baldy01 is on the right lines as we have checked the spray arms and they look ok. The problem is I can't get into the back of the unit. There are no obvious screws to undo and no other obvious way in.
I checked what I could of the waste but nothing obvious and without being able to get further down the line of the waste then I am stuck.
Welcome any other ideas on how to get into this beast.
Cheers
XH28
Back to top
 Alert Moderators
Sleepyhead
from United Kingdom
Thanked: 27 times
PostPosted: Thu Sep 28, 2006 8:47 pm Reply with quote
There's nothing in the back of it, it's all underneath.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Diplomat dishwasher not cleaning properly 2 960 Mon Feb 05, 2007 5:26 pm
Please Help! AEG dishwasher not cleaning properly 2 200 Wed Nov 24, 2010 5:14 pm
Hotpoint BFI620 not dissolving tablets or cleaning properly 3 500 Fri Jul 23, 2010 4:29 pm
Prima LPR600 not cleaning properly - no fault indicated 3 100 Sun May 13, 2012 8:39 pm
Bosch Classixx dishwasher is suddenly not cleaning. 5 960 Sun Jul 11, 2010 7:50 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
