Joined: 27 Sep 2006 Posts: 3 Location: Norfolk, United Kingdom Thanked: 0 times
Posted: Wed Sep 27, 2006 1:50 pm Post Subject:
Add a Socket in Sink Cupboard.
I am planning my kitchen with an integrated Dishwasher and Washing Machine either side of my sink cupboard.
Should I add a socket in the sink cupboard with a cutout (easy access but not sure if this is allowed) or behind each of the appliances.
Joined: 10 Jul 2006 Posts: 340 Location: Cleveland, United Kingdom Thanked: 0 times
Posted: Wed Sep 27, 2006 1:57 pm Post Subject:
Remember Part P! You'll need to have installed switched fused spurs, this allows for the appliances to be isolated in the events of a fault without having to pull the kitchen apart to turn a plug off
Posted: Wed Sep 27, 2006 2:18 pm Post Subject:
Like this?
Ok, so if I put a switched fused spur for each behind the sink cupboard with a cutout for access and connected these to 13A plug sockets behind the appliances?
Posted: Wed Sep 27, 2006 2:24 pm Post Subject:
Part P means its notifable work and only a competant person should be doing it. The switched fused spurs would be located above the work surfaces and the lead from the appliance would go to that. theres no plug, the fuse is actually in the spur, so no need for one
Joined: 04 May 2006 Posts: 134 Location: United Kingdom Thanked: 0 times
Posted: Wed Sep 27, 2006 5:08 pm Post Subject:
I disagree. The last thing I'd advise anyone to do is cut the plug off a new appliance and connect it into a fused spur before buryng the flex behind tiling or plaster. What happens if it goes wrong and the appliance needs to be returned after you've butchered the cable? There's also a good chance that the cable wouldn't be long enough to allow the appliance to be pulled out from under the worktops for maintenance if you do this, and I'd have thought it pretty bad practise to be burying flex in walls anyway.
If you want to go down this road, it's generally considered good practise to fit a double pole switch above the worktop feeding a unswitched socket below the worktop where you can plug the appliance in. Alternatively, although it may not be best practise there's nothing wrong (by the regs) in installing a normal switched socket below the worktop, either behind the appliance or in an adjacent cupboard (but mounted on the building fabric).
Joined: 27 Aug 2003 Posts: 21984 Location: London, United Kingdom Thanked: 78 times
Posted: Wed Sep 27, 2006 5:27 pm Post Subject:
Or if you don't mind cutting the plug off, you can replace it with an unfused one, e.g. 15A BS546 or Schuko, and supply the socket from a switched FCU above the worktop, or if you have a lot of appliances together, from a grid of switch and fuse modules.
__________________ I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Joined: 11 Jan 2004 Posts: 16482 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Thu Sep 28, 2006 12:19 am Post Subject:
That's my preferred method.
__________________ As George Michael once said, "..if you're gonna do it, do it right, right?"
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
