I've just drained all my first floor rads to change some pipe work. The boiler is also on the first floor.
After inserting the filling key, and opening the grey valve, nothing happens. There's pressure getting through to the grey valve, as I can remove the black screw cap on the other side of the key and there's loads of water pressure. I'm dong this with all the rads in the house on, with bleed valves removed, and theres not even a hiss from one of them.
I've gone though the documentation, and the system was fully working before I did this - so am I missing something obvious?
One thing I'm wondering is what's in the black plastic housing just on the other side of the bleed key - some kind of non-return valve I guess - does thiis ever get stuck? Oh, and I've bled some pressure from the main pressure vessel thinking this might help make the external water pressure overcome some internal valve, but no joy.
Cheers
Gary
Cheers
Gary
