DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Olive removing tool
Goto page Previous  1, 2, 3, 4  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Softus
from United Kingdom
Thanked: 8 times
PostPosted: Tue Nov 28, 2006 11:15 pm Reply with quote
I'm with micktheframer on this one....
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 200 times
PostPosted: Tue Nov 28, 2006 11:31 pm Reply with quote
sharp hacksaw unless there is no room...then ill use the pinch type cutters and swear like b*****r when it pinches the pipe icon_biggrin.gif
Back to top
 Alert Moderators
Slugbabydotcom
from Pakistan
Thanked: 44 times
PostPosted: Wed Nov 29, 2006 3:54 am Reply with quote
Olive removing tools !
Ya bunch of big pink frilly girlie things! I've got enough junk tools to cart about already.
Easy does it with the hacksaw then stick a screwdriver in the slot and twist.
Suppose if it got used often enough it might justify its existence, but I cant see one getting a place in my toy box
Back to top
 Alert Moderators
sm1thson
from United Kingdom
PostPosted: Wed Nov 29, 2006 9:22 am Reply with quote
I had to remove some olives for the first time at the weekend i just lightly gripped them with mold grips and twisted them off.
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 8 times
PostPosted: Wed Nov 29, 2006 10:00 am Reply with quote
Slugbabydotcom wrote:
...I cant see one getting a place in my toy box
Back to top
 Alert Moderators
frogmore
from United Kingdom
PostPosted: Mon Oct 29, 2007 5:17 pm Reply with quote
I've just fitted several new rads. Three of them were weeping. I drained down and fitted fresh PTFE tape and all but one of them is now fine.
The problem one is reusing the old copper pipes to the rads and I left the old olives in place. If the weeping is slight, will they seal themselves or should I tighten up harder or must new olives be fitted? I really don't want to damage the pipes and have to replace them as access is very tricky. New carpet being laid next Weds so I need to sort this by then.
David
Back to top
 Alert Moderators
Waterworxsw
from United Kingdom
PostPosted: Mon Oct 29, 2007 5:36 pm Reply with quote
Intrigued to see how well the tools work though.
Al
Back to top
 Alert Moderators
EliteHeat
from United Kingdom
Thanked: 2 times
PostPosted: Mon Oct 29, 2007 10:25 pm Reply with quote
I've used all 3 methods, hacksaw, olive puller and olive splitter.
I've just spent 50 quid on 15 & 22mm splitters and they are by far the best way of getting the olives off.
Mind you, even better is just turning or wacking them off if they will let you.
P.S. I never managed to engage the nut on a 22mm pipe with the 15/22mm pullers.
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 502 times
PostPosted: Mon Oct 29, 2007 10:49 pm Reply with quote
im with waterworxsw on this one pump pliers or just plain old hacksaw. what next a soldering iron that can solder 15-28mm copper. icon_lol.gif
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 8 times
PostPosted: Mon Oct 29, 2007 11:04 pm Reply with quote
holty wrote:
pump pliers or just plain old hacksaw.[
Indeedy-deedy. Pump pliers are great when you're bored and want to spend a few moments struggling and swearing. And a hacksaw is great for poking a dent in the skirting board and nicking the pipework.
Or, you could buy a tool that gets off every olive, every time, quickly and neatly. Cutters/splitters work so well that it's almost disappointing.
Quote:
Ha ha ha ha ha ha ha ha ha ha. Is that a pile of cannelloni on the floor or have my sides just split?
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 502 times
PostPosted: Mon Oct 29, 2007 11:17 pm Reply with quote
if it saves me 15-20 quid on a tool. then every time i get the 20-30 pence olive off using my normal tools, then yes im happy as hapy can be.until my boss gives me money for tools then ill keep doing it the old way.p.s by the way softus i wasnt takin the p%^s about the soldering iron, you can actually buy them icon_wink.gif
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 8 times
PostPosted: Mon Oct 29, 2007 11:26 pm Reply with quote
In that case you should throw away all your tools except for a hacksaw, a hammer and a big screwdriver, because you could saw off every nut you find and do the new ones up by hitting them. That would be a big saving.
My olive cutters have easily paid for themselves by saving time that I've turned into more earnings by being able to do more jobs in a day.
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 502 times
PostPosted: Mon Oct 29, 2007 11:38 pm Reply with quote
not arguing on this one, depends on the person, im always arguing with fellow tradesman on the subject if bending pipe is quicker than soldering and i cant understand how soldering is better or quicker. each to there own, its funny how different tradesperson have there own views on different tools or different ways.
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 51 times
PostPosted: Tue Oct 30, 2007 12:03 am Reply with quote
I bought both olive cutters but used them so rarely they went rusty, 90% of the time if pump pliers don't tease it off it will be crushed onto the pipe and need the section replacing anyway.
Back to top
 Alert Moderators
Terrywookfit
from Antarctica
Thanked: 136 times
PostPosted: Tue Oct 30, 2007 12:03 pm Reply with quote
I suppose there are tight a**es in every walk of life!!
I bought a 15mm splitter as I had 19 pairs of valves to change !!
I would consider it paid for itself on that job alone due to saved time!!
Its still working after 2 years!!
If not abused they are excellent tools!!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 2 of 4
Jump to:
Olive Pulling Tool 15 1840 Sat Feb 21, 2009 8:06 pm
Removing an Olive from 15mm Chrome Plated Copper Pipe 2 920 Sat Aug 25, 2007 4:57 pm
removing olive issue 4 440 Mon May 17, 2010 8:13 am
Best way to remove an olive ? 15 900 Wed Jan 13, 2010 11:00 pm
Changing a TRV. Olive question 8 440 Fri May 01, 2009 6:39 pm
DIYnot
