DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replaced Radiator - now problems with bleeding pump
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Snetty
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 29, 2006 1:12 pm    Post Subject:
Reply with quote Thanks
Hi there,
I recently replaced our kitchen radiator for a nice new chrome towel radiator. I had to drain the system, but when I did I found that the kitchen radiator (plus a couple of others) seemed to have been attached straight to the hot water system rather than the radiator circuit, so I had to turn off the hot water too and drain that. I fitted the radiator and refilled everything and bled the radiators so all should be sorted. Only thing is, that the pump clearly has air in it (you can hear it), but when I open the bleed valve, no air rushes out, I can literally take the valve out and look inside. The obvious answer to this would be a valve that I haven't switched back on, but I've double checked everything and I'm sure that they're all fine. Is this a common occurance? Can anyone think of something obvious that I've missed.?
Also, because of this, I'm not sure about having the boiler on. I've had it on for a short time, but the outbound pipe gets very hot (durr). I assume that the boiler works via convection and that this is normal, but I don't want to leave it on until I've had confirmation of this.
All help is much appreciated.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ChrisR
from United Kingdom
Thanked: 62 times
PostPosted: Fri Sep 29, 2006 1:27 pm    Post Subject:
SOunds like an odd system - more details please. Boiler, controls...
Has the HW cylinder got any writing on it.
Back to top
 Alert Moderators
Snetty
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 29, 2006 1:31 pm    Post Subject:
No writing on the cylinder that I can see.
The boiler is gas powered, make and model I have no idea about, but as far as I'm aware it's never been replaced so that would make it about 25 years old.
Controller? er, just a thermostat in the lounge.
Sorry if I'm being a bit vague, I'm not sure exactly what you're asking.
Back to top
 Alert Moderators
Snetty
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 30, 2006 11:10 am    Post Subject:
Bump..
Can nobody help me?
Back to top
 Alert Moderators
goooba769
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 30, 2006 11:32 am    Post Subject:
Snetty the bit where you mentioned some radiators are on the hotwater circuit sounds very odd. Not sure how that would work? Assume you have an old system which heats the rad system and the hot water is heated in the tank using heat from rad system+element?
Back to top
 Alert Moderators
Snetty
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 30, 2006 12:21 pm    Post Subject:
Actually it's the other way around, the boiler heats the water in the hot water tank, which then heats the rad system.
Yeah, I know why it's been done though, the 2 rads that aren't on the rad circuit are very close to the boiler, simple lazyness on the house builders part.
I've decided that I'm out of my depth now though, so will be calling in a plumber on monday, even if it's just to advise me.
Back to top
 Alert Moderators
goooba769
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 30, 2006 1:25 pm    Post Subject:
Snetty that seems like an odd system never seen one which heats the water which in turn heats the rad system.
http://www.diydoctor.org.uk/projects/boilers.htm
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sat Sep 30, 2006 3:57 pm    Post Subject:
He may not know what its called but he has a thermal store!
Probably two pumps as well!
Tony
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
no hot water\central heating pump just replaced 11 720 Wed Nov 23, 2005 7:00 pm
downstairs rads cold, replaced pump still no CH 6 700 Sun Sep 30, 2007 4:46 pm
Replaced pump & actuator but pump keeps running 11 1360 Sun Oct 21, 2007 8:31 am
Replaced pump and now have gremlins in my heating! 6 560 Sun May 07, 2006 8:11 am
Help!...Water Pump may need to be replaced 3 840 Thu Feb 07, 2008 7:55 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
