My kitchen monobloc mixer tap is leaking from where the tap swivels - I'm assuming I need to replace some sort of washer? I've tried removing the mixer spout but can't get it off - any tips??
are there any screws at the back, is there a screw ring where it fits into the block,
IF NOT
you have to pull the spout up and slowly twist it to the left normally. you will feel a little click if your lucky this is where the key as latched into the groove inside at this point you pull straight up.
if your very lucky spout comes out replace the two O rings lubricate and pop it back in the same way.
'Taydo' mentioned a monobloc spout in a reply, I am trying to obtain one of these (the pull out type with the rubber o rings) to replace mine (leaking due to split) can anyone suggest a supplier for these ?
