DIYnot
Local | Network
   DIYnot > Forums
Local | Network
1 radiator not working
This topic originated from the How to page called Problems associated with radiators
Click here to return to the page called Problems associated with radiators.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
jaynemit61
from United Kingdom
PostPosted: Fri Sep 29, 2006 9:25 pm Reply with quote
I have 1 radiator not working, I have bleed this and turned it up to the highest setting on the temp guage. Any ideas as to what is wrong. All other work fine.
Back to top
 Alert Moderators
Moz
from United Kingdom
PostPosted: Fri Sep 29, 2006 9:27 pm Reply with quote
Back to top
 Alert Moderators
jaynemit61
from United Kingdom
PostPosted: Fri Sep 29, 2006 9:29 pm Reply with quote
what is a trv?
Back to top
 Alert Moderators
gasmarkone
from United Kingdom
PostPosted: Fri Sep 29, 2006 9:30 pm Reply with quote
Sticking pin on the TRV [that valve you turned up!]. How handy are you? The repair could involve some WD40, pair of pliers or maybe just a [not too large] hammer!
Back to top
 Alert Moderators
Moz
from United Kingdom
PostPosted: Fri Sep 29, 2006 9:31 pm Reply with quote
Thermostatic Radiator Valve ...
Back to top
 Alert Moderators
gasmarkone
from United Kingdom
PostPosted: Fri Sep 29, 2006 9:38 pm Reply with quote
Or an easier option could involve a telephone, a cup of tea and a cheque book!!!! icon_lol.gif
Back to top
 Alert Moderators
jordsbabe
from United Kingdom
PostPosted: Fri Nov 09, 2007 8:16 pm Reply with quote
I have the same problem all radiatiors work apart from one!!!! It was working fine last winter! So what do I do with the pliers WD40?
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Fri Nov 09, 2007 10:58 pm Reply with quote
Take the head off the trv and gently tap the pin with a hammer.
Back to top
 Alert Moderators
jordsbabe
from United Kingdom
PostPosted: Sat Nov 10, 2007 9:47 pm Reply with quote
Thanks Just one more question i can't seem to get the tvr off, does it screw off?
Back to top
 Alert Moderators
jordsbabe
from United Kingdom
PostPosted: Sat Nov 10, 2007 10:30 pm Reply with quote
Back to top
 Alert Moderators
jordsbabe
from United Kingdom
PostPosted: Sat Nov 10, 2007 10:33 pm Reply with quote
jordsbabe wrote:
it's ok panic over i've got it lol! thank you so much for your help!
Back to top
 Alert Moderators
hezekiah
from United Kingdom
PostPosted: Sat Jan 16, 2010 7:42 pm Reply with quote
I removed the TRV, and checked the pin, and it's spring operation is working fine. I removed the pin erronously, and the radiator began to warm up, but once I replaced the pin it cooled down again.
Only one radiator doesn't work in the whole house (in my room!) and I can't work out what the problem is.
Back to top
 Alert Moderators
ManxPlumber
from United Kingdom
Thanked: 8 times
PostPosted: Sat Jan 16, 2010 9:55 pm Reply with quote
When the heating is on, are both tails feeding the rad hot, or just one?
...is the lockshield open at the other end of the rad?
Back to top
 Alert Moderators
hezekiah
from United Kingdom
PostPosted: Sat Jan 16, 2010 9:59 pm Reply with quote
The lockshield is definitely on. Only the pipe attached to the lockshield is warm. Like I said, it got warmer when water was bursting out of the TRV end (I accidentally took the pin out, although replaced it successfully, and checked it functioned properly).
Back to top
 Alert Moderators
gazzaman22
from Ireland
PostPosted: Wed Jun 30, 2010 10:16 am Reply with quote
Hi Guys, One rad wouldn't work for me. So i tried the suggested but broke the little metal pin end...so now i need a new one...what are these called and where would i get one?...B&Q?, while trying to fix it i broke the whole housing unit it sits in as well so i'm gonna need the whole valve that screw to rad icon_redface.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
1 radiator not working 5 420 Sun Jul 15, 2007 11:49 am
radiator upstairs not working 6 420 Fri Nov 30, 2007 12:12 pm
Radiator furthest from boiler not working????? please help 8 1800 Tue Nov 21, 2006 11:47 am
Radiator not working 2 520 Fri Nov 10, 2006 6:10 pm
One radiator not working 4 660 Fri Jun 22, 2007 9:11 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
