DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Apollo CH and Overheat Stat and TC
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Pacman
from United Kingdom
PostPosted: Sat Sep 30, 2006 2:40 pm Reply with quote
Following on from other thread had the boiler (Thorn Apollo 15/30) serviced and the TC changed and the Oheat stat replaced, the guy changed some 'A' clips so that the cowl pulled tight against the back as the old clips were threaded and all seemed well the boiler fired up and we have had heat and HW for 2 days now.
BUT
Now the boiler won't light AGAIN it's gone out and won't relight, now it seems the Oheat stat is gone again but I don't want to keep calling someone back to just change it so it works for a day and pops again.
Why would the Oheat stat keep going? is it meant to fail safe or is it meant to cool down and reset? or is there something else?
The Stat he replaced was on the left hand side above the TC and buts up against the heat exchanger, he didn't change the Low stat where is this? should it need changing?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3564 times
PostPosted: Sat Sep 30, 2006 3:19 pm Reply with quote
That model is a low water content and is very sensitive to the flow rate and will overheat if TRVs close and you have no system bypass.
I thought the overheat stat was in series with the thermocouple and once it had cooled down the pilot will relight?
Tony
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1164 times
PostPosted: Sat Sep 30, 2006 4:21 pm Reply with quote
Don't assume it may be overheating there are other reasons for pilot outage. Sometimes once overheat stats have opened despite cooling and closing the pilot can be difficult to light.
Unfortunately there are many reasons for the pilot to go out.
Get the installer back and start by checking the following:
Pilot not blocked (crisp blue flame)
Pilot adjusted correctly.
Genuine TC and o/heat stat used
Top socket not split/corroded
Pilot shield in place
Pilot sight glass not cracked/seals OK
Casings seals OK
Casing correctly fitted especially around TC/pilot supply pipework
Heat exchanger not blocked (very common - and can take an hour to clean out)
Blocked gas valve inlet filter
Flue not corroded
Flue outer cover plate not missing
Flue not in a high wind position
High thermostat working correctly
Bypass pipework
Bypass adjustment
Pump not running slow/ impeler not blocked
Pump overrun operating correctly
Blockages/poor water circulation
Incorrect or faulty wiring
and probably several other items..........
Sometimes it can take a few visits - just start with the simplest and cheapest problems to solve.
Back to top
 Alert Moderators
Pacman
from United Kingdom
PostPosted: Sat Sep 30, 2006 6:28 pm Reply with quote
Does a high stat fail safe buy being closed circuit or a open circuit?
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1164 times
PostPosted: Sat Sep 30, 2006 6:45 pm Reply with quote
The high stat goes open circuit once the flow pipe water hits around 80 centigrade, this then turns off the gas valve solenoid. Putting the thermostat switch on low switches in the low stat that probably opens up at 60 or 65 centigrade.
These stats have nothing to do with getting the pilot to light.
When is the service engineer coming back?
Back to top
 Alert Moderators
corgiman
from United Kingdom
Thanked: 46 times
PostPosted: Sat Sep 30, 2006 7:21 pm Reply with quote
soundfs to me like a circulation problem
Back to top
 Alert Moderators
Pacman
from United Kingdom
PostPosted: Sun Oct 01, 2006 11:22 am Reply with quote
Got the guy back to have a look, he simply bent the TC more into the pilot light and now its holding, all working good now. icon_biggrin.gif
I'm selling the house soon and would like to have the boiler certified as safe before i sell, what should I expect from a engineer to certify as safe i.e. is a service record enough or is there a scheme?
Also when I look up a Corgi engineer on their website it gives me 10 or 12 within a couple of miles what's the best way of picking one or can anyone recomend an engineer around the Gatwick area
Back to top
 Alert Moderators
Gasguru
from United Kingdom
Thanked: 1164 times
PostPosted: Sun Oct 01, 2006 11:32 am Reply with quote
Bending a TC is not a standard procedure. On universal types the intrusion into the flame can be adjusted a little on the thread.
Are you trying to tell us he wasn't corgi registered. Otherwise why didn't
you get him to issue a gas safety record whilst he was there. A registered engineer has a legal responsibilty to ensure the boiler is safe and operating correctly and these safety checks are mandatory.
I hope the heat exchanger was checked as they are renowned for becoming blocked and are a pain to clean. Its a dead givaway for highlighting lack of proper servicing.
Back to top
 Alert Moderators
Pacman
from United Kingdom
PostPosted: Sun Oct 01, 2006 11:40 am Reply with quote
Coming back in the week to complete the task, just want to know what to expect like the gas safety record you mentioned,
heat exchanger is a ok
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3564 times
PostPosted: Sun Oct 01, 2006 12:38 pm Reply with quote
As explained there is no significant adjustment on the thermocouple but the pilot can be adjusted to better illuminate the thermocouple.
The standard arrangement on your boiler has a very large pilot flame which never normally gives any illumination problems.
On the original thermocouple on that boiler the over heat stat has screwed connections to connect to terminals on the thermocouple lead. The usual method now is 6 mm spade connectors.
The list avobe missed out checking that any screwed connectors are tight and the connection surfaces are clean. A little crocus paper will help.
An assessment of any problems can be made by measuring the thermocouple output voltage on each of the interruptor tags.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Myson Apollo Overheat Stat versus Hi stat specification 8 460 Sat Jan 24, 2009 7:40 pm
Myson Apollo - Overheat on High Stat 5 320 Thu Jan 14, 2010 7:29 pm
Boiler Tripping on Overheat Stat 3x a Day 4 480 Sun Feb 21, 2010 3:46 pm
Potterton Suprima lock out problem - overheat stat? 3 40 Mon Feb 06, 2012 6:05 pm
Overheat stat for Radiation fuelsaver 15rs 2 320 Wed Nov 25, 2009 10:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
