DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
hall way and Landing circuit
This topic originated from the How to page called Types of electrical circuits
Click here to return to the page called Types of electrical circuits.
  View previous topic :: View next topic
Author Message
NooNoo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 30, 2006 2:50 pm    Post Subject:
Reply with quote Thanks
I have a single gang switch on the landing down to a double gang in the hallway. I have swapped the hallway for a dimmer switch. I have wired in the terminals exactly the same on the dimmer as per the double switch. When I turn the upstairs on from the dimmer, and turn up to top limit, the downstairs come on aswell! Also when both are on, I can't turn the downstairs off ! Have I got the wrong type of dimmer ?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Sep 30, 2006 2:55 pm    Post Subject:
if you have as you say wired it exactly the same then it must work, since it doesn't it would imply you have wired it wrong.
why do you want a dimmer any way? i think that for a hall / stairs they should never be used, besides with your set up, suppose you are at the top of the stairs, and its too dim? you have to go downstairs to turn it up, or suppose being dim you dont see something and trip over it (no you cant have 2 ordianairy dimmers operating the same light)
I suggest you put the old switch back and get that to work right first
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Sat Sep 30, 2006 2:58 pm    Post Subject:
chances are, you wired it wrong.
was the old one:
Code:
L1  L2 /  COM
COM  / L1  L2
Did you take note of how the switches are divided? The line down the middle ought to give some idea - I'm guessing you thought the top row was the first switch, and the bottom row was the second switch?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Sat Sep 30, 2006 10:10 pm    Post Subject:
Yes, check both switches (new & old) not all switches are laid out the same. This sort of thing keeps us sparkys in easy profitable work - keep it up!!
Back to top
 Alert Moderators
NooNoo
from United Kingdom
Thanked: 0 times
PostPosted: Sun Oct 01, 2006 10:13 pm    Post Subject:
Hallway / Landing circuit
was the old one:
Code:
L1  L2 /  COM
COM  / L1  L2
icon_biggrin.gif Exactly right. Thanks for the help.
Back to top
 Alert Moderators
NooNoo
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 03, 2006 9:54 am    Post Subject:
2 gang dimmer downstairs single switch upstairs
I have now a different problem. I wired in as per your explanation, and the dimmers work fine. When I turn the upstairs lights off by the original upstairs switch, when I try to turn them on from the dimmer downstairs they won't come on. Now I've heard mantion of dimmers and 'slave switches' do I need one of these? [/quote]
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Tue Oct 03, 2006 10:58 am    Post Subject:
Nope, the dimmers you refer to are if you want to be able to dim from two locations. I take it you only have a dimmer as one of the two way switches and a normal switch as the other, this setup is fine. It sounds more likely you have got the wires mixed up in the switch or the dimmer. What colour wires do you have in the dimmer and in the switch and where do they connect?
Back to top
 Alert Moderators
NooNoo
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 03, 2006 11:41 am    Post Subject:
The single gang upstairs I haven't touched. The 2 gang dimmer downstairs has :
switch 1: yellow - common, red - L1
switch 2: black - common, blue L1, red - L2
This is as per the original 2 gang switch. What do you think ? Are there any safe variations I could try ?
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Tue Oct 03, 2006 6:15 pm    Post Subject:
as I said in the other post, it sounds like you require a slave dimmer. Is the dimmer VARILIGHT branded by any chance?
Back to top
 Alert Moderators
NooNoo
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 03, 2006 8:39 pm    Post Subject:
icon_rolleyes.gif I'll hang my head in shame. All the wiring was correct. A broken live was all I had. Dimmer now works fine and the upstairs switch does what is supposed to.
Thanks for the advice..
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
hall landing 2 way switch 2 500 Wed Dec 13, 2006 5:21 pm
hall and landing light switches 14 1160 Sat Nov 25, 2006 1:30 pm
3 gang hall and 2 gang landing problem 7 620 Thu Nov 02, 2006 12:53 pm
NEWBOY NEEDS HELP, 2 WAY HALL/LANDING SWITCH. 13 500 Mon Sep 29, 2008 2:57 pm
Hall and Landing lights nightmare!!! 5 420 Wed Aug 27, 2008 8:30 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
