Domina 80 e leaking
30 Sep 2006
Glasgow
I decided to bleed my radiators which was fine,when i went to turn on heating the pressure was at 0 and the bar warning light was on due to insufficient pressure. I turned the filling loop screw and water started to go through but then it began pouring out from underneath the boiler and there was no increse in pressure which has left me with no central heating. Help!!
Is the filling loop a stainless braided hose? If so check the hose is hand tight each end. Sometimes this type of loop drips a little whilst filling.
If its definately leaking from the boiler itself, wherabouts exactly?
Top up to 0.5 Bar unless you know the expansion vessel in the boiler has been checked recently.
Yeah the water is definately coming from where hot inlet pipe goes in to boiler housing and also at both ends. Was worried that I may be damaging any electrics, was thinking of taking boiler cover off for closer inspection
