I've had a search and not yet found a definative answer.
As I am due to pour concrete 6" deep all over my drive next Saturday, getting a cable in now would be a good option, but I'm still a bit unsure of exactly what to use.
I need 2 double sockets and 5x60W bulbs in my garage.
I have a small consumer unit for the garage with a 6A and 16A MCB and 63A 30mA RCCB, so I intent to use the 6A one for the lights and the 16A one for the sockets.
The garage is about 15M away from the house.
There is a convienient air brick right under the floor under the main CU in the house which I intend to use for the cable to exit the house.
Do I go for 6mm SWA cable and bury it under the concrete or plastic conduit with 2.5mm T&E, also buried under the concrete?
I also intend to use a 20A MCB in the main CU in the house to supply the garage CU.
Any thoughts or advice anyone?
Cheers,
Pat...
Cheers,
Pat...
