24i junior overheat
1 Oct 2006
London
First time i tried central heating in new house. It works ok but the boiler overheat light flashes everytime i turn the heating off, Boiler pressure is ok, radiators get hot. Overheat resets after approx 5 mins. Boiler is Worcester 24i Junior and is less than a year old, hot water works fine.
You have not made it clear if this is a combi or heat only boiler with a HW tank.
If its a heat only then it sounds as if the pump is wrongly wired and not providing an over run.
If its a combi then thats an odd fault if its on the heating only and the hot water is really OK.
Tony
whats the actual fault then? if the hot waters ok rads ok but a red light flashes after they get hot?
is it not some sort of anti-cycle/overrun indicator?
