Ok, with almost no plumbing knowledge, except what I have been reading lately, due to major kithchen alterations I am doing, I would like to know what type of fittings to use to extend
1/ the cold water feed for a diswasher
2/ both hot and cold water feeds for a mixer tap on new sink.
Presently, the cold water dishwasher feed has a valve which can be opened or closed, attached to the end of the pipe (15/16mm), and I need to extend this about another meter or so round an internal corner.
The hot and cold water feeds come off at 90 degrees vertically with inline valves and flexible tap connectors, and these need to be moved/repositioned some 12 inches further away than wher they are now.
I am at a loss as to what use or how to do these 2 jobs due to the varieties of fittings and pipes.
I hope the above is clear, and doesn't sound too complicated.
