Ceramic Disc Tap Compatibility
17 Apr 2005
Plymouth
Is it possible to replace a washer-type kitchen tap valve with a ceramic disc type or does the whole tAp assembly have to be changed?
Many thanks,
DavidP
This is a bit hit and miss, because it depends on finding a valve of matching length.
If you measure the valve length and (if you want to keep the same handles) the number of splines, then you might find that Lunns have what you need.
Many thanks for your advice Softus - I'll follow it up straight away.
Cheers,
DaveP
