DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
another fused spur question
This topic originated from the How to page called Adding a spur to a ring circuit from a socket
Click here to return to the page called Adding a spur to a ring circuit from a socket.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
mike502
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 07, 2004 3:14 pm    Post Subject:
Reply with quote Thanks
I'm trying to install a new socket in our home... having identified a suitably located ring-main socket from which to run a spur, I discovered this was already being used to power our burglar alarm, via a fused spur.
Can I run another cable, either from the original socket, or from the burglar alarm fuse unit, to power my new socket?
Mike
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Feb 07, 2004 5:44 pm    Post Subject:
depends on the rating of the fuse in the consumers unit for the alrm, you can do as you suggest but if the fuse is too small, but it also depends on size of cable to fcu.
can you not break into the ring and put new socket into existing ring?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
mike502
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 08, 2004 1:08 pm    Post Subject:
Thanks for the reply. Breaking into the ring is an option but slightly more awkward for routing of cables. Maybe I'll just call in a professional...
PS for what it's worth, the fuse in the alarm consumer unit is 13A
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 08, 2004 4:41 pm    Post Subject:
13A fuse in a consumers unit? dont mean the fcu do you (white box same size as a switchh) it should be 3 amp.
i would still break into the ring, thats waht any electrciain should do, so you will pay for something you could do your self.
__________________
Forum = Opinions
Back to top
 Alert Moderators
mike502
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 08, 2004 5:38 pm    Post Subject:
I'm confused as to what should have which fuse ...I do mean a white box the same size as a switch - is that the consumer's unit? That has a 13A fuse in it.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 08, 2004 5:46 pm    Post Subject:
sorry i was busy earlier, no it should have a 3 A fuse
fcu (fused connection unit)
cosumers unit
other makes of fcu and consumers units are available
__________________
Forum = Opinions
Back to top
 Alert Moderators
mike502
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 08, 2004 6:18 pm    Post Subject:
OK, I'm getting there slowly. So it looks like I should change the fuse in the fcu...
As for the consumer unit - well, the alarm doesn't have its own mcb, it's on a spur from the ring main.
And back to my original question... can I run another cable from what I now know to be an fcu to power a socket?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 08, 2004 7:34 pm    Post Subject:
you can, but it will be protected via the 3 amp fuse you are going to put in.
why not put the new socket on the ring, you can do it very easily
__________________
Forum = Opinions
Back to top
 Alert Moderators
mike502
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 08, 2004 7:48 pm    Post Subject:
You know what, I get the impression you think I should put the new socket on the ring. icon_lol.gif
I'll give it a go - thanks for your help!
mike
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 08, 2004 7:55 pm    Post Subject:
it is always better to put an addition IN the ring as opposed to a spur.
if you want the new socket in very close to the cosummers unit you could
main switch to OFF
remove one cable for ring from mcb (put this into new socket)
install new 2.5mm cable from new socket back to mcb
so now new socket is in ring
even though off the incoming side of the switch is LIVE
turn mains back on
__________________
Forum = Opinions
Back to top
 Alert Moderators
Millennium_Boy
from United Kingdom
Thanked: 0 times
PostPosted: Sun Feb 08, 2004 8:46 pm    Post Subject:
Fused Spur
An alternative way, is to put an Unswitched Fused Connection Unit on the ring in a convenient spot, and fit a 13amp fuse in it, then run a 2.5 sq mm cable off its output terminals, to the new socket location, and connect it accordingly.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 08, 2004 8:48 pm    Post Subject:
Millenium_Boy, done that, been there. thats what the poster asked if he could do (connect to the fcu)
__________________
Forum = Opinions
Back to top
 Alert Moderators
mike502
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 14, 2004 11:56 am    Post Subject:
OK, back again this weekend...
My biggest problem with extending the ring main is locating and routing cables... the house is a new one with solid concrete floors and I have no idea where the cables run between sockets! Any suggestions if there's anything I can do to find them (and to put in new ones) without cutting through large amounts of plasterboard...which would not make me popular, particuarly on Valentine's Day!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Feb 15, 2004 1:20 am    Post Subject:
Breezer - about to open up an old arguement between me & thee (breezer groans)
Some BA panel manufacturers insist on 2 A fuse in the FCU.
As I said in a previous post, I had a problem (I suspect with a faulty PCB) on a BA panel, and they refused to replace under wty because I had used a 3A fuse not 2A in the FCU. So I went off to WF and bought a bagfull of 2A fuses.........
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sun Feb 15, 2004 7:44 am    Post Subject:
seconds away, round 2:
still don't see the point (2 a Fuse) when 3 is fine, and also there is a 1a fuse in its own "minature fcu" cam across a "galaxy panel" it had a 20mm glass 1 A fuse, so what does it matter ehat is in the fcu, so long as it protects the cable.
.........and securespark, has breezer in a half nelson, but breezer does a half flip and body slam to securespark and ......yes, yes the ref is counting one,......two.......
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Hey it's a fused spur question 12 760 Mon Apr 18, 2005 5:41 pm
Switched fused spur controlling 2 appliances 2 460 Thu Feb 22, 2007 10:48 am
fused spur or spur? 7 266 Wed Feb 28, 2007 7:05 pm
Outside light fittings specify fused spur? 9 840 Fri Feb 16, 2007 7:41 pm
fused spur off a cooker switch 13 660 Wed Feb 07, 2007 8:17 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
