DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Installing external lighting
This topic originated from the How to page called Security lighting
Click here to return to the page called Security lighting.
  View previous topic :: View next topic
Author Message
anglojock
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 07, 2004 4:44 pm    Post Subject:
Reply with quote Thanks
I want to install approx 5 off external wall lights and would appreciate some guidance how to go about this. Ideally I want to use dawn-dusk lights and not PIR sensored. I also want to fit a switch into this circuit. I have not attempted this and don't know where to start. Can you advise?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Feb 07, 2004 5:47 pm    Post Subject:
its easy to do, but i am not sure if you are able to do it. i am not being funny when i ask this, but can you confidently wire a plug?
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
anglojock
from United Kingdom
Thanked: 0 times
PostPosted: Sat Feb 07, 2004 6:46 pm    Post Subject:
erm.................yep I am able to wire a plug.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Feb 07, 2004 7:02 pm    Post Subject:
ok then, sorry but i had to ask.
you wire all the lights up in paralel , using 1.5mm t & e
at the first light you wire in a dusk / dawn sensor.
(comes with instructions) but basically it wants a premanent supply, and gives a switched live when its dark
the swicthed live is connected to the live of the first light
the neutral is connected to the neutral of the first light.
your incoming supply (via fcu) is conected direct to the sensor (you already have the link there for the neutral
for an override switch you connect a cable across the incoming live and the switched live
all earths should be connected together
it may be an idea to spur off a socket, via an fcu
parts:
1.5 t & e cable
suitable external lights (1000w max for sensor)
clips
1 gang 1 way switch (over ride)
patress to suit
FCU
patress to suit
dusk / dawn sensor
2.5mm cable
earth sleaving
5 amp connector block
sundries
optional:
weather proof box to mount sensor / make connections
swear box
you can get the whole lot from screwfix
__________________
Forum = Opinions
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
External lighting too many wires 9 500 Thu Jun 22, 2006 12:09 pm
External Lighting Query 8 600 Wed Mar 12, 2008 1:34 pm
External Lighting 3 440 Sun Apr 30, 2006 11:20 am
External Lighting 5 440 Mon Feb 13, 2006 9:50 pm
External Mains Supply For Garden Lighting 10 920 Wed Sep 07, 2005 2:57 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
