- Joined
- 2 Oct 2006
- Messages
- 6,652
- Reaction score
- 290
- Country
Hello all,
First some back ground to my problem:
Marathon Floor standing Boiler.
Feed & Expansion tank in loft.
Hot water storage cylinder in cupboard (on upstairs landing).
Cannot see a Pump and/or diverter valve anywhere so I assume this is a Gravity fed system?
Central Heating is 8mm Minibore with Manifolds etc.
Anyway, I've just moved a radiator in one of the bedrooms. To do this I used a set of 'Header Tank Bungs' and plugged the Feed & Expansion tank Cold feed and Expansion pipe.
I cut into the pipework 'one pipe at a time' to avoid an 'Unexpected' drain down! After re-routing the pipework and mounting a new radiator, I took out the 'Bungs'. Then I opened the new radiator valves and the system began to pressurise. I then opened the bleed nipple until fully pressurised.
So everything was fine... until later that day when my wife went to run a bath and said 'The Hot Water pressure used to be better than that'! I checked the flow rate on the bath and other hot water taps in the house and the flow rate is definitely slower than before.
Any ideas? I'd appreciate your advice.
Thanks.
Thanks.
