Cause of Boiler kettling? Pump?
21 Nov 2005
Hi all,
I'm after some advice please. Im pretty much a novice on boiler issues but would like to see if any of you can help diagnose the problem before i seek professional help.
I have a fairly old back boiler system- baxi bermuda.
A while ago when the heating was turned on after a short time a noise starts to come from the pump next to storage tank upstairs. shortly after the back boiler also started to kettle and has been like that for a while. it would kettle then shut off, the pump would make a weird noise as if its seized and the converter inside is making a noise. anyway after a couple of weeks it blew a fuse- those 5amp one thats goes in the switch.
Accept my apologies for the bad terminology ,
i think the pump does need replacing, but is that the likely cause, or is that the symptoms of a dead pump?
Also can it be scale or some thing.
Any ideas or solutions much appreciated.
first thing to do is ..check that there is water in the system.
good starting point
sheesh bster you are putting us old lags to shame
wanna job??? :):)
Hi guys, just as an update, i purchased a wilo gold a like for like for the old smc. but fitting it was a nightmare, the valve connections were welded on so it seemed. so i isolated the valves and cut through the caps with a hacksaw
just finished now, sounds a little noisy the pump, i let the air out and sounds ok and running smooth. just give it a day or two to be sure.
mind you even though the old pump was in a state it wasnt ceased.
Could be the converter within it that packed up?
since changing the pump my ground floor radiators don't warm but upstairs are fine. i've bled the radiators and pump?
any ideas?
Try "balancing" - see faq. Otherwise, could be a sludge problem.
