Hi
As it happens I'm the DIY person in the house and my husband dose the cooking.
Can you help guys?
My Baxi Combi 105e is 3 years old. All was fine until 6 months ago when pressure started to creep up on a gauge
(even to 3.5 bar-I had to use safety valve to release it) and water running hot and cold.
Boiler is always set to CH and HW. CH is run by thermostat located in a front room.
When shower or any other mixer tap is on, boiler fires up and I will get hot water for 20 seconds
then boiler cuts off-water gets cold all in an endless cycle. None of the boiler neons are flashing indicating any faults.
Water pressure in taps and shower has not changed since I had this problem.
Last time CH system was flashed was 18 months ago and some inhibiter added. Apparently we do have hard water down here.
Which parts of the boiler can be affected and possibly need replacing?
As far as I know boiler has been installed by an engineer however not corgi registered. How can I have this boiler certified ?
I want to be save but don't want to get to any trouble. I will call the plumber promise.
Thank you very much for any good ideas.
Kasia
Can you help guys?
Kasia
