Joined: 01 Oct 2006 Posts: 16 Location: Cleveland, United Kingdom Thanked: 0 times
Posted: Thu Oct 05, 2006 11:36 am Post Subject:
adding a Consumer Unit
i am thinking of wiring my loft, with a lighting circit (6a) and a socket circit (32a) ive got a spare fuse slot on my main consumer unit witch is 45a could i wire a cu in my loft? what type of cable you suggest i use?
Joined: 05 Sep 2005 Posts: 829 Location: Hull, United Kingdom Thanked: 0 times
Posted: Thu Oct 05, 2006 12:25 pm Post Subject:
in my loft i have access to the ceiling lights below so will be tapping off them (theres only 4 lights upstairs anyway), so just needs the sockets so i will be extending the ring from the level below. (again my upstairs has its own ring and i dont run much off it and wont be running much in the loft).
Im not a spark but i wouldnt of thought the loft needs its own CU unless you have a lot of high power stuff up there or currently have a lot of high power stuff on your present rings?
Posted: Thu Oct 05, 2006 2:15 pm Post Subject:
hmm, as i said Im not a spark so Im not going to comment on how much power is too much (and a spark would probably need to add up what else you are running +cable lengths +everything else).
but even if you are heavily loading your ring, why not just add a new ring for the loft from the spare breaker and tap into the upstairs lights for lightage (as the cables are allready in the loft i presume)?
I cant see the need for a CU in the loft, but your house is probably a lot bigger than mine and a spark (or someone more experienced) will probablycome along and put us both right, lol.
Joined: 08 Jul 2006 Posts: 567 Location: Yorkshire, United Kingdom Thanked: 1 time
Posted: Thu Oct 05, 2006 4:19 pm Post Subject:
Nothing new to add but i believe smithson and plugwash are right. there's no need for a new CU at all.
the light should be able to be taken from the existing circuit and you may even be able to extend your ring circuit aswell, at worst i would think a new ring for the loft.....or a radial.
as plug says also... notifiable.
__________________ remember......a little bit of knowledge is often more dangerous than no knowledge at all!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
