In the last few days my shower stops running while having a shower then comes back on then off intermittently. the low pressure light shows at this time. Can anyone help to suggest a problem?
Almost impossible to tell remotely as there's a multitude of problems that can cause this sort of thing. Try descaling the spray head (in vinegar works!) as a first off. Make sure there's not a water supply problem (happened to me for quite a while before the water board found a burst main down the road). After that could be scaled in the heater itself and then there is the possiblility of there being a fault in the sensors and switches that control the shower. What sort of shower is it?
