DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing old switch
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
AA2e72E
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 07, 2006 11:51 am    Post Subject:
Reply with quote Thanks
Existing switch has RED at the top, BLACK at the bottom (only has 2 connections) and the backplate has an earth terminal to which the earth is presently connected.
New switch as 3 terminals. COM, L1 and L2.
What colour goes to COM, to L1, to L2?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
HDRW
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 07, 2006 11:55 am    Post Subject:
Re: Replacing old switch
AA2e72E wrote:
Existing switch has RED at the top, BLACK at the bottom (only has 2 connections) and the backplate has an eatth terminal.
New switch as 2 terminals. COM, L1 and L2.
One of them to COM, the other to L1 - it doesn't matter which way round, although it would be better to have the red to COM, because that's the way it would be if it was ever converted to use two-way switching (hall/landing stylee).
And the black should really have a red sleeve on it to indicate that it's Switched Live, not Neutral.
Cheers,
Howard
__________________
Back to top
 Alert Moderators
AA2e72E
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 07, 2006 12:00 pm    Post Subject:
Thank you HDRW.
So, it is:
RED to COM,
BLACK with a red sleeve to L1,
The EARTH (with a yellow/green sleeve) to the EARTH terminal?
I'll be much obliged if you would confirm this, thanks.
Back to top
 Alert Moderators
HDRW
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 07, 2006 12:08 pm    Post Subject:
AA2e72E wrote:
Thank you HDRW.
So, it is:
RED to COM,
Yup, that's it!
Cheers,
Howard
__________________
Back to top
 Alert Moderators
AA2e72E
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 07, 2006 12:12 pm    Post Subject:
Thank you very much Howard.
First time 'play' with electrics without help; so I am a little apprehensive.
PS: Your signature message/statement is frightenning! It is stated in jest, isn't?
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Oct 07, 2006 12:20 pm    Post Subject:
most signatures on this site have some sort of humour, even mine
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
Hevski
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 11, 2006 6:22 pm    Post Subject:
Aarrrgggh!
____________________________
Lynda, moderator
please note forum rule 20
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Oct 11, 2006 6:58 pm    Post Subject:
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
replacing existing switch with dimmer - confused about cabli 4 2260 Thu Mar 01, 2007 1:24 pm
Replacing Dimmer Switch Coil? 10 840 Fri Mar 02, 2007 4:03 pm
Replacing a double light switch 2 3760 Wed Apr 11, 2007 3:09 pm
Replacing a double light switch 5 1740 Mon Feb 19, 2007 1:30 pm
replacing a light switch with a sensor 7 440 Wed Jan 31, 2007 3:37 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
