does not take in the conditioner
lp3
9 Feb 2004
i have had the machine nearly 3 years. it has now stopped taking in the fabric conditioner. The power is fine.
mine does that its a coffee perculator, what's your's?
it would help if I had more info
(but it sounds like the double cold water inlet valve)
This man is good!
What are the lottery numbers for this Saturday Breezer? ;)
some people do not understand how some things work. but did YOU know there are 2 cold water , 1 hot water valves on a washing mc (3 cold if its a washer dryer)
what may be obvious to you and me isn't to others, i also notice you didnt reply first :LOL:
I had this problem on mine and all it was, was that when you took you took out the soap drawer and looked above it, the jet holes were blocked with gunge. After cleaning it out it worked fine again...
