Pressure drop Ariston Genus 27RFFI boiler
9 Oct 2006
Worcestershire
I have need to top up the boiler to 1.5 bar every 2 days . I have had the pressure relieve valve replaced and there is no water loss via the pipe going outside. This week I turned the system off and once the pipeworkhad gone cold I saw water dripping from under the boiler casing. I topped the pressure up to 1.5 bar and within a few minutes the water had dripped out and the pressure was at zero.
What is the likely cause and do I need an engineer to fix it
it will probably be the air vent inside the boiler
Unless you can fix it your self then I would suggest that you will need a CORGI engineer.
I went to one of these and found the primary heat exchanger leaking!
Tony
Thanks for your reponse. More work has been done and the boiler is still problematical. Latest suggestion is to replace the 5 year old Ariston Genus 27RFFI with a Worcester Bosch .
Any views on which company in the market seems to have the "best " products
My view is that you do not have a competent engineer if he cannot repair a five y.o. boiler.
Why not sack ( and dont pay ) your CORGI engineer and call the manufacturers for their service engineer.
Tony
