celaun
Joined: 10 Oct 2006 Posts: 2 Location: Essex, United Kingdom Thanked: 0 times
Posted: Tue Oct 10, 2006 2:59 pm Post Subject: do i need an earth wire? |
I want to replace my light fittings in the hallway and bathroom. On removing the old fittings (plastic) I've found that I have only live and neutral wires (1black, 1 red) coming from the ceiling. The new light fittings I've bought (which are metal) require an earth wire to be fitted.
My question is whether I can fit the new lights with no earth wire or will this mean the lights are 'live' (bearing in mind they are metal fittings). If I can't connect without an earth then is there any other option apart from re-wiring?
Thanks |
didthathurt
Joined: 19 Aug 2006 Posts: 311 Location: Kent, United Kingdom Thanked: 0 times
Posted: Tue Oct 10, 2006 3:05 pm Post Subject: |
This is a very common problem with some of the older houses that don't have an earth in lighting circuits. One thing is for sure: Do Not - Under Any Circumstances - use a fitting designed to be earthed without an earth.
I would advise you get a PIR (Periodic Inspection Report) done. For about £100 it will give you the low down on what you have, what you do not have and what needs doing - and may save your spending money piecemeal and then needing to have it redone sometime soon. __________________ Being a professional doesn't mean I'm any good - just that I get paid for doing it! |
celaun
Posted: Tue Oct 10, 2006 3:22 pm Post Subject: |
Thanks for such a quick reply. looks like my new light fittings will have to stay in their box for now! |
ebee
Joined: 14 Aug 2005 Posts: 1067 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Tue Oct 10, 2006 9:05 pm Post Subject: |
DEFINATELY |
