hot water pipes banging
10 Oct 2006
Merseyside
I have a worcester 28si ll combi boiler. My problem is, if I run my hot water tap at any more than half pressure, the boiler/pipes bang and the water flow splutters at the same rate as the bangs. At a lower flow rate the water comes out perfectly well and at the correct temperature. The central heating side of things seem to be fine.
