DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric Fire
This topic originated from the How to page called Fitting a Fused Connection Unit
Click here to return to the page called Fitting a Fused Connection Unit.
  View previous topic :: View next topic
Author Message
richyd
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 10, 2004 8:48 am    Post Subject:
Electric Fire
Reply with quote Thanks
I have an electric fire which is to be mounted to a flat wall surface.
Directly behind the fire is the plug socket which it will be connected to, but obviously with the plug in the socket the fire will not mount flush against the wall.
Can I replace the socket with a switched FCU with flex outlet and connect the fire directly using this to make it more flush against the wall?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
another_sparky
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 10, 2004 11:18 am    Post Subject:
I'd certainly be sure to check there is enough space behind the fire to allow dissipation of any heat buliding up at the back.
If not you would find the cable quickly melting!
Is the fire designed to be fixed directly to the wall?
And yes, you could use a switched FCU and connect direct.
(assuming you exisiting supply line is 13 amps)
Canyou not move the fire slightly to one side or move the fcu below the fire.?
Back to top
 Alert Moderators
richyd
from United Kingdom
Thanked: 0 times
PostPosted: Tue Feb 10, 2004 3:02 pm    Post Subject:
Many thanks for your reply
The fire is freestanding and is suitable for flat wall fixing (rather than inset), it comes with a spacer kit to do so. The plug socket is a couple of inches above the floor, and will always be behind the fire
The heat is dispersed via fans out the front of the fire, the rear of the fire does not appear to heat up much! To be honest with you it is just there as a feature, and will rarely if at all be used for heating!!
My plan was to take the plug off the fire, and direct connect the cable from the fire straight into the FCU (which will replace the current plug socket).
If you can see any other potential problems with this let me know!
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Feb 10, 2004 3:15 pm    Post Subject:
Isolation in an emergency?
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Feb 11, 2004 1:00 am    Post Subject:
I wouldn't put the FCU behind the fire not least bcause of heat issues. As Ban says, isolation is an important issue.
I see many appliances (eg washers) wired under tops with the socket outlet feeding them right behind. An elderley lady customer of mine had a fire in her tumble drier and could not turn it off. She didn't have the presence of mind to switch off at the mains. Bless her, she panicked and ran into the street and the neigbour called the brigade, and they only just saved the place. 32K's worth of damage.
It's lazy and a pain in the a**e to do this. move the fcu if at all possible or even the fire if position is not critical.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Wed Feb 11, 2004 9:52 am    Post Subject:
A few years ago my tumble has a burning smell and found the fluff was building up round the internal switch.Is this what can cause a fire or is it something else ?
Back to top
 Alert Moderators
richyd
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 11, 2004 11:05 am    Post Subject:
Many thanks for all prompt replies - have been very helpful...I will probably move the FCU for safety precautions.
Thanks again
Rich
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Wed Feb 11, 2004 10:52 pm    Post Subject:
masona
I never got to the bottom of the cause, but your problem sounds like it may be cause for concern.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Wed Feb 11, 2004 11:03 pm    Post Subject:
sorry i just notced masona's post (its me age)
fluff can also build up in / around the heating element. some td's have a fluff filter which must be regularly cleaned, even so some fluff may get past it.
when a td is serviced any fluff found must be cleaned out (its surprising where it does get into)
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Thu Feb 12, 2004 9:03 pm    Post Subject:
breezer
wots yur age got 2 do with fluffy td's???????????????
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Installing Electric fire into an existing fire grate 8 2820 Thu Sep 15, 2005 8:20 am
Wall hanging electric fire 3 360 Mon Feb 25, 2008 10:53 pm
Electric Fire 11 520 Mon May 21, 2007 1:29 pm
Electric Fire Wiring 4 300 Tue Jan 27, 2009 4:25 pm
electric fire stones 7 420 Fri Jan 12, 2007 6:19 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
