Our boiler is a Britony 100 combi and has recently been repaired (new diverter valve as CH would not come on). Since then it has developed a leak, making a small puddle by the sink (dripping probably once every 20 secs) i think from the main water inlet, but I can't be sure (have not taken the front off yet). The pressure in the gauge has also dropped below the minimum operating pressure (0.7 bar), although it always was a bit low and hovered around the minimum pressure. However, the water still heats up when the taps are turned on, and the CH seems to be working OK, although the hot water is taking a bit longer to get hot. Would the leak be causing the drop in pressure? Would it be relatively easy to stop the leak if the pipe just needs tweaking a bit to tighten it up? I'm a bit wary of opening any valves or anything knowing as i do absolutely zilch about heating systems
any advice gratefully received
thanks
fi
thanks
fi
