DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Tiling on wooden bathroom floor
This topic originated from the How to page called Ceramic floor tiles
Click here to return to the page called Ceramic floor tiles.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
daveturnbull
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 11, 2006 10:01 pm    Post Subject:
Reply with quote Thanks
Can you please help? im going to tile my bathroom floor and was going to do it straight onto the floorboards which seem in good condition. I have been told that it is ok to tile on to floor boards as long as it is secure and level as well as using flexible adhesive. Other people have said (and noticed some on this forum) that you need to put WBP plywood down. i would just like to know the pros and cons of both and what is the best way to go about it. Cheers for your time
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
GrahamT
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 13, 2006 9:10 pm    Post Subject:
WBP is mainly for areas that will get a lot of water (shower area) so its not necessarily needed elsewhere, but you probably want to lay a thin sheet to give yourself an even surface to tile to.
Back to top
 Alert Moderators
gcol
from United Kingdom
Thanked: 12 times
PostPosted: Sat Oct 14, 2006 9:49 am    Post Subject:
Boarding:
Pros
Your tiles stay stuck down.
Give a nice flat surface to tile on.
Cons
Extra cost and time.
Floor is a little higher.
Not boarding:
Pros
Cons
The grout will crack and the tiles may loosen.
__________________
If I'm curt with you it's because time is a factor. The Wolf.
Back to top
 Alert Moderators
mattytiler
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 13, 2007 11:19 am    Post Subject:
you have to board, 100% or tiles will come up, or just crack.
minimum ply depth 15mm,
or you can use 6mm hardie backer tiling boards, which are stronger, and waterproof.
http://www.pureadhesion.co.uk/category/37/hardi-backer-boards
you tiles will definitely crack if you do not reinforce your floor, seen it hundreds of times
Hope this helps
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Ceramic Tiling A Wooden Bathroom Floor 8 20460 Thu Sep 09, 2004 9:58 am
bathroom tiling - replace damaged floorboards or whole floor 2 820 Mon Mar 16, 2009 12:21 pm
CERAMIC FLOOR TILING IN BATHROOM UPSTAIRS? 2 6520 Fri Sep 29, 2006 7:19 am
Tiling onto uneven bathroom floor (DIY novice) 3 1240 Thu Jul 07, 2005 2:11 pm
Tiling bathroom floor 2 840 Wed Aug 16, 2006 12:11 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
