At the beginning of the cycle it fills with water and then the ECO & PREWASH lights start flashing. I have tipped the machine to get the water out but it is still the same.
I've taken the machine outside and connected it to the power/water. Filters have been cleaned.
At the start of a cycle the machine fills with water and it starts to heat the water. The LEDs do not show a fault anymore but the water is not circulating in the machine. I've taken the back cover off and the water can be seen bubbling up the clear tube but is not reaching the propeller inside. The water pumps out of the machine ok when I end the programme.
