Anyone know a simple conversion for this crappy system?, it has a wall mounted stat which has hot water only if turned anti clockwise, heating only if turned clockwise and an equal share in the middle. Primatic cylinder, no cylinder stat, single channel clock. Can I rewire it simply to a spring return valve or is a total upgrade to a y plan required?. 5 wires on the actuator by the way.
