DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Insulation board and downlights
Author Message
SIman
from United Kingdom
PostPosted: Fri Oct 20, 2006 7:10 pm Reply with quote
I am about to install 2 downlights (GU10s) in a pitched roof/ceiling that is almost fully filled with Kingspan insulation board. How far back should the insulation board be cut for a GU10 fixture? Obviously it's a trade off between thermal performance of the ceiling and the amount of space needed to cool the fixture. Anyone know any figures for this? The ceiling is plasterboard/40mm Kingspan over rafters/90mm Kingspan between rafters/50mm air gap/felt/clay tiles. I actually only want to fit energy saving GU10s, but I guess I'll have to make the fixture ok for 50W GU10s to satisfy Mr Building Inspector!
Back to top
 Alert Moderators
2face
from United Kingdom
Thanked: 1 time
PostPosted: Fri Oct 20, 2006 7:12 pm Reply with quote
i am sure the distance is 110 mm from anything.. this figure is in my mind .
Back to top
 Alert Moderators
Adam_151
from United Kingdom
Thanked: 148 times
PostPosted: Fri Oct 20, 2006 7:17 pm Reply with quote
You should consult the manufacters instructions, if you can not locate this information, you should contact the manufacters themselvees
Therefore it would also be prudent to speak to buildings control at the council as well
Try approved document L, otherwise ask the building inspector
I'm not sure (although I'd hope so) , but it would certainly be very much common sense to do so
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Under floor electric heating, which insulation board? 10 220 Mon Aug 06, 2012 9:36 pm
insulation resistance test split load board 3 960 Mon Aug 13, 2007 10:26 am
downlights and insulation 8 2080 Sat May 26, 2007 12:54 pm
LED downlights - insulation question 2 80 Fri Dec 30, 2011 12:58 pm
keeping insulation away from downlights 6 680 Thu Mar 16, 2006 6:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
