I am refitting my bathroom and found an unusual setup when I pulled out the old toilet and floor. The toilet waste was not routed "out the wall" so to speak but instead it came out a 90º pan connector and then a 87.5º bend under the floor - then there was a boss coming off the pipe under the floor and they had routed 32mm pipe up through a wall cavity and eventually through the roof. I don't think this is compliant so want to change it out - however I do not want to run directly out the wall behind the toilet as it is now to be located on the front wall of the house and the main soil & vent stack is around the side of the house. Hence my plan was to fit a branch below the toilet and take a pipe up to a durgo then box that in. The toilet is on it's own indepenent branch of the waste system i.e. no sinks or baths etc. tie into the 110mm before it ties into the main soil & vent at the lower end of the fully vented stack that everything else ties into around the side of the house. Hence I am thinking that the flood level of the system will only be the top of the toilet U-bend (i.e. I can have my durgo mounted quite low and hence hide it in the corner under the stairs).
Does this sound reasonable? Any help appreciated!!
