I've drained the CH system and replaced the manual valves with thermostatic ones. However after filling the system back up again and bleeding the radiators the pump cuts out after aprox 30 seconds and the insufficient system pressure LED comes on and the pump turns off.
The automatic air release valve on the pump is open but there sounds like there is air in the boiler. The boiler is probably at the highest point in the whole CH system.
I can't figure out what's wrong.
Please help, I'm freezing
