door locked and light on
22 Oct 2006
hi
i put my hotpoint aquarius machine on...went away...heard a bang...came back and it wasn't working...replaced the fuse...it then went onto the cycle and appeared to finish. trouble is, the door lock light is still on, despite the cycle being over, and i can't the door undo, even if i turn off the mains...any ideas? many thanks
It sounds from the symptoms you describe that the door interlock has firstly gone short circuit blowing the fuse and ended up open circuit with the interlock in the closed position replacement door interlock switch required.
many thanks indeed
i now seem to have the problem of the washing not filling up with water and washing!
Depending on what actually happened with the door lock it's possible that the fault has also damaged the pcb.
no, the problem with the door has not been resolved.
Does the door lock light now come on when you close the door before selecting your programme. If it does not check the door interlock has been fitted properly, failing that as sleepyhead suggested a possibilty has been a surge through the pcb causing damage when your lock went short circuit although because your prograame went through a wash cycle and completed it after you replaced the mains fuse it would have possibly indicated the pcb ok at that point.
