Adding a 24hr timer to a Baxi HE133+ Combi
22 Nov 2004
Hampshire
Hi
I have a Baxi HE133+ Combi with a built in timer mechanism.
Would it be possible to add a secondary timer to it and override the existing built in timer?
For example, when I had the system replaced, I had a DRAYTON LIFESTYLE LP722 removed from the old system. Could this be fitted to the Baxi?
I need to have more control (mainly at the weekends) over my heating
as I find the built in timer does not allow for the extra on time needed at the weekends.
Do you think this would be a better option?
I was just thinking of using up an unused timer.
ok, can you recommend a suitable wireless programmable room thermostat?
I'm not overly keen on wireless technology as its a little hit and miss at times. Could I replace my existing room stat?
I find the wireless stuff faultless, but if you want to replace your exisiting thermostat with a volt-free wired programmable thermostat there are loads around. The Honeywell CM67 is good, but overly complex - google it and you will find lots of examples.
