martin3129
Joined: 24 Oct 2006 Posts: 2 Location: Cambridgeshire, United Kingdom Thanked: 0 times
Posted: Tue Oct 24, 2006 7:34 am Post Subject: removing old handrail |
im new to this and need some help. i'm trying to replace and old handrail but cannot workout how it is attached to the newel. I can see what i think is an attachment through the newel which is at a 90% angle to the handrail. I have drilled this out and hit something hard (i assume metal), but i still cannot see how it is attached to the newel. Help |
Jasonb
Joined: 20 Aug 2004 Posts: 2001 Location: Surrey, United Kingdom Thanked: 6 times
Posted: Tue Oct 24, 2006 11:43 am Post Subject: |
The handrail is likely to be joined with a mortice & tennon joint, what you drilled out was probably a peg that secured the tennon.
The only way to get the handrail off without removing the newel will be to cut it flush with the newel post.
This pic should give you an idea of the joint, you can just see the peg.
Jason |
Tozzy
Joined: 06 May 2006 Posts: 338 Location: Nottinghamshire, United Kingdom Thanked: 0 times
martin3129
Posted: Thu Oct 26, 2006 5:55 am Post Subject: |
thanks for your help...... |
