DIYnot
Local | Network
   DIYnot > Forums
Local | Network
thorn emi apollo pilot light
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
falloverpete
from United Kingdom
PostPosted: Tue Oct 24, 2006 6:19 pm Reply with quote
Hello,
I have a Thorn EMI Apollo boiler and the pilot light gave me some trouble last year but it finnaly stayed lit throughout the winter. This year however i could not get it to stay lit. I replaced the thermocouple, and the pilot still wont stay lit. I fitted the thermocouple as i saw it but should the two ends be connected loosely or firmly or doesn't it matter? The End of the thermo couple is in the flame and does glow red. Any ideas i could try?, short of calling out a professional?
suggestions greatly appreciated.
Pete
Back to top
 Alert Moderators
BOB.DOLE
from United Kingdom
PostPosted: Tue Oct 24, 2006 6:23 pm Reply with quote
your gas valve could be faulty get it tested
Back to top
 Alert Moderators
garethgas
from United Kingdom
Thanked: 9 times
PostPosted: Tue Oct 24, 2006 6:25 pm Reply with quote
Hi Pete,
This is probably not what you want to hear...but get a Corgi in.
You've interfered with the combution chamber and its seal.
Even if the boiler worked, you'd still run the risk of fumes seeping out if its not done properly.
Also, the thermocouple on these have an interrupter on them so they're not standard ones.
Sorry to be the bearer of bad news but its the best advice I can give you.
On a more positive note, get it serviced while he's at it and you'll be right for another year.
Good luck
Back to top
 Alert Moderators
falloverpete
from United Kingdom
PostPosted: Wed Oct 25, 2006 11:41 am Reply with quote
How much do you charge Gareth?
Cheers
FP
Back to top
 Alert Moderators
falloverpete
from United Kingdom
PostPosted: Wed Oct 25, 2006 12:49 pm Reply with quote
I dont know if this is important, but the end of the thermo couple which inserts into the boiler ( not pilot light end ) is flat ended, on the old thermocouple it was bullet ended. Is there a part variance? And would it make a difference? I know i will burn in the fires of hell ( or my kitchen ) for taking off the cover of my boiler and thinking i know anything but any help greatly appreciated.
Thanks for previos replies
Back to top
 Alert Moderators
Pacman
from United Kingdom
PostPosted: Wed Oct 25, 2006 1:31 pm Reply with quote
I've had all sorts of problems with my pilot light on my Thorn Apollo
Tried cheapo way = intermittent and unreliable
Ended up paying for the thing to be fully done by a pro only to find out it wasn't running properly in the first place, hopefully will be ok when fixed tomorrow
Back to top
 Alert Moderators
2face
from United Kingdom
Thanked: 1 time
PostPosted: Wed Oct 25, 2006 2:52 pm Reply with quote
sounds to me like interupter /over head stat is faulty .. pull out the plastic spades on the gas valve and screw straight in the the valve there fore by passing the safety devise .. does it work now ?
remeber this is only for testing and please dont run the boiler in this state .purely fault diagnosis.
Back to top
 Alert Moderators
falloverpete
from United Kingdom
PostPosted: Wed Oct 25, 2006 3:52 pm Reply with quote
Thanks Packman and 2face. I could call out a corgi registered engineer, but i am moving house soon so would rather a temprary fix rather than an overhaul, If i were staying in the property i would do this.
The thermo stat runs as two wires from the thermocouple up to a widget that sits on one of the pipes, Isn't it to cut out the boiler if your water gets overheated? Well i think it is 10 to replace it, I don't see how i could test it by bypassing it. There are two spades screwed into the interuppter which then run to the stat widget which sits on the pipe.
I wouldn't mind paying for a service before selling the property as i don't want to kill the next occupants. Any reputable corgi engineers anyone would stick their neck out to refer in the Cardiff Area?
( i really thought it could be the thermocouple end )
Thanks for the help
FP
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 64 times
PostPosted: Wed Oct 25, 2006 4:16 pm Reply with quote
You would screw the tc straight into the gas valve by unscrewing the housing with the spade connectors in it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
pilot light wont stay on, thorn apollo boiler 12 2680 Sat Feb 11, 2006 12:16 am
Thorn Apollo, pilot flame extinguished by strong winds 7 860 Tue Feb 21, 2006 11:42 pm
Thorn Apollo 50/65 Heating Boiler 3 660 Sat Dec 01, 2007 8:36 pm
Thorn EMI Apollo 40 boiler 18 38720 Sun Oct 14, 2007 4:44 pm
Advice needed thorn emi apollo boiler 2 500 Tue Nov 13, 2007 7:57 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
